I need to remove the driver's left door sill cover (that goes over the front trunk / engine compartment releases and the seat memory presets) because my wife pressed on the engine release and it popped off (inside the cover). D'oh!
Long story short, this looks like something I can fix myself instead of taking it in.
The car is a 2002.
Any help is greatly appreciated!
1. Remove plastic plugs and undo the hexagon socket head bolts 2 from the sill by approx. 4 - 5 threads.
2. Lift sill 1 upwards out of the bottom support with a plastic spatula and press out. Check fastening clips 4, replace if necessary.
