OBD II Pcodes
P0154 Oxygen sensor ahead of TWC, bank 2
Potential causes:
Open circuit in signal wire or ground wire
Oxygen sensor heating not functioning
Output stage in DME control module faulty
Internal resistance too high
Check:
– Wiring harness
– Oxygen sensor
– DME control module
P1119 Heating of oxygen sensor ahead of TWC, bank 2
Potential causes:
Oxygen Sensor Heating Before TWC, Bank 2
Check:
– Open Circuit
- Short Circuit
- Oxygen Sensor
If it is not the wiring then you need a new O2 sensor.
OBD II Pcodes
Potential causes:
Check:
– Wiring harness
– Oxygen sensor
Potential causes:
Check:
– Open Circuit
- Short Circuit
- Oxygen Sensor
Thanks Loren. BTW....the sensor that I need to check is on driver side before the cat ( closest to engine) right?
