Hello,
I have had a new GAHH top installed on a 1998 boxster, after the installation the top has 2 problems:
1) the side do not correctly go inside the B pillar as described in TSB 6128 9/97
2) the top is too tight.
Now that I found the TSB and got access to it I'll have the installer repair the point 1.
For point 2, the problem is that normally when the top is all the way up (top light turned off) to close the latch I just have to work the mechanism and it does so easily. Now the front part of the latch does not quite reach far enough in the windscreen hole to grab and so I have to pull on the front of the top to get it to latch. I asked the installer to loosen it but he tells me that the roof will probably loosen and that it is better to have it installed tight.
I don't want to have to apply force on the roof mechanism so I'll ask him to loosen it regardless of what he thinks (his credibility with me is quite low now that he messed up the installation of the roof and could not find the TSB while it took me a non expert about 1h to find the solution on this forum). On the other hand I want to be able to retighten it myself if necessary.
Can someone post pictures and explanation on how to adjust that part of the roof mechanism.
Thank you
Benoit Cerrina
PS:
if you leave in the Charlotte, NC area, I don't know who to recommend for upholstery work but I can tell you one shop to avoid.
Thanks to Tools Pants I now know where the adjusment bolts are and will loosen the top shortly
I didnt know there were adjustment bolts to loosen the tops tight canvas fit. You are suppose to Steam the top so that it'l stretch during the installation, Makes it really hard if you dont... I know this first hand, I had to lay 2 old wooden head boards and a Iroc rim with tire on the roof to get the latch to grab on.
Incase your wondering, after leaving the top closed for 2 days and parked in the sun. the top only requires a slight pull with one hand to latch on and close the top. Sometimes doesnt require pulling at all.
