I can never get the tank completely full - according to the indicator. :huh: If I set the fill rate at moderate (using the catch on the pump nozzle), it shuts off before the tank is full. If I set the fill rate at minimum, it doesn't shut off - ugly mess with gas shooting out of car. :angry: I'll never do that again. :oops:
I am aware that over filling can cause problems for one of the smog/fuel systems, I think.
So, what do others do? :unsure: Do I head out on the road with less than a full tank?
Thanks ;)
Thanks ;)
Hi.
Pretty sure I read a TSB about that. Contribute the $25 and you can see for yourself. It's well worth the money.
Many other interesting things along with the specific TSB you need.
Joe
Thanks ;)
Hi.
Joe
Are you referring to: TSB for the Boxster dated 3/99 2015 Fuel Tank Hose Modification?
If this TSB came out in '99 and my car is an '01, should I consider that Porsche fixed the problem before my car was made?
Is there another TSB which you refer to?
Loren?
David
p.s. I have been a contributing member since shortly after I registered. :cheers:
Porsche has had the issue with the crimped hose at least a couple of times.
Another possibility is a blow fuse that will shut the vent off.
A third possibility is a bad canister/purge valve circuit (that again shuts the vent off - usually you get a CEL with this.
