Seems to hesitate low down the rev range in gears 1 or 2. Pulls away nicely as the accelerator goes down - then has a flat spot, then kicks in as it is depressed further. Done all the obvious i.e. cleaned MAF with contact cleaner, ran a tank through with injector cleaner - still upto it's tricks - could it be a stretched accelerator cable?
1998 Boxster 2.5 - Manual
Yeah sounds like my issue in some ways, When i replaced my fuel pump, i noticed alot of this sand looking material stuck on the screen on the pump itself, i think some of this got through and past the filter and is stuck in one of the injectors... Porsche said they have a test that can determine what is the wrong with it and it starts at $270.... keyword, STARTS.
Loren - this car has 67k on the clock, could the O2 sensors be on the way out - would this cause the flat spot/ hesitation at low revs?
Sorted now - MAF had gone bad and both lambda sensors were reading out of spec - all replaced and it now drives like a new car. No hesitation and no banging harshly into 1st and 2nd gears!
