I need the part number for the air change-over valve in the secondary air injection system. It is #2 in the image below. Thanks in advance!
Geoff
Car info: 1997 986 5-spd.
Thanks Tool Pants. I got the part info from another post, but the guy at the dealership knew exactly which part I wanted. Apparently this part is a frequent problem.
A couple of questions related to the replacement of this part for anyone who has done it themselves:
1. Is it possible to replace it without removing the passenger-side intake plenum?
2. If not, any caveats for taking off the plenum?
3. Does the gasket between the plenum and the cylinder head/block need to be replaced?
4. Torque specs for the bolts holding down the plenum?
Geoff
  • 2 years later...
I'm wondering the same thing as Geoff - can it be replaced without removing the intake - I have a 1997 Boxster, replaced secondary air pump already, still failing intermittently and tripping the CEL, going to try the change-over valve now. Any info on replacing this would be awesome.
