I have a 99 996 with H&R springs aznd otherwise stock suspension. Any word on spacer sizes front and rear?
There is a good thread on this a little way down the forum.
The short answer is Porsche sells and recommends two wheel spacer combinations. The first combo is four 5 mm spacers on all four wheels. This is sold as a kit that includes longer wheel bolts and longer wheels locks. 1999-2001 GT3's use these spacers. The second option is 5 mm spacers on the front and 17 mm spacers on the rear. If you go this route, you'll need to get some custom sized lug bolts made up for the rear spacers.
Karl
