CEL is on
P1126 Oxygen Sensing Adaptation Area 1 (Cylinders 4 - 6) - Rich Threshold
Sounds like maybe the left bank O2 sensor is failing. Typically when they go bad they make the car run rich.
<--could be wrong, wait for Loren's answer.
I changed all (4) O2 sensors (after market) about 400 miles ago. The code was P1275 at that time.
Could that be MAF sensor?
It is not the O2 sensors and it is likely not the MAF. If it were the MAF why would your engine be running too lean only on cylinders 4-6?
I think you should look for intake leaks, a cracked oil filler hose, oil separator or other intake related problem.
Rodger...Could you check code P1119 for me? What does it mean? I switched the O2 sensors between bank 1 and bank 2. Guessing one of the new sensor may be defective.
P1119 Oxygen Sensor Heating 2 Ahead of Catalytic Converter - Below Lower Limit
If I am reading this right, it sounds like the O2 sensor closest to the head isn't heating up properly. Not sure which side is "side 2", though. Right bank is cylinders 1-3, so maybe it's the left bank (cyl. 4-6)?
Ask the experts!
