GT3 Clutch/Flywheel in a 99'C@ 6speed?
I have ben told that it will fit 964,5,993 and 993 turbo. not too sure about the DMFW, there was some discussion about one having 6 bolts and the other having 7. But I think the clutch parts will fit.
Hi I changed the info to add that it was an 04 GT3 clutch. I would really like to know for sure as I would not want to buy one from someone and then find out it would not work. I was assuming that the flywheels would be different so I would have to use the whole setup. Please let me know if this helps clarify.
Thanks JR
I am sitting next to an '04 GT3 clutch (that is FS) as I speak. I can give you the P/N's if it will help. As to fitment, send me a message directly and I can give you reliable contacts that can steer you in the right direction.
If you don't go to a LWFW this set up will probablly work with your stock DMFW. The LWFW is thinner and needs a different guide tube and release bearing. We can verify all this if you might be interested.
Edited by RayGT3
Well if you have one let's say I am interested. and help me with your acronyms LWFW? I am planning on running an Evo SC on the car and well Yadda Yadda Yadda. Please let me know Thanks. JR
Ouch after rereading Loren's note its not going to work. Darn it.
Edited by ViolaGT3
