We (just got) a 2002 996 Targa.
I have a 2005 Boxster S 987S.
Are the wheel offsets and sizes compatible between these cars?
If not, which would need spacers to mount the other's wheels?
Thanks for your help!
tmc
tmc
In the rear the Carrera has 65 mm offset, the Boxter 47 mm. This is with stock 18x10´s. You can use Boxster wheels directly on the Carrera but you need spacers the other way around. I believe the fronts are identical. (ET 50-55 mm)
Edited by BjornH
