The light in the speedometer of my '71 911T has burned out. When I remove the speedometer housing from the dashboard, I don't see any obvious place for a light bulb. Any help on how I replace this?
The light is a round shaped connector that fits into a cylinder hole in the back of the speedo. A wire runs directly into it. Just pull the lip outward with your fingernails. Bulb is inside the cylinder you pull out. Best I remember there are two of them.
Thank you very much!! Even the local Porsche dealership wasn't sure. You were exactly right, and yes, there are two of them.
