Is there a way to tell if suspension components are M030 by looking at individual part #'s and paint dabs? I have a 2001 C2 cab w/6 speed.
Tom
For a US M030 on MY01 Cab:
Front springs would be marked Grey/Yellow
Rear springs would be marked Grey/Red
Thanks Loren. How about ROW?
For an RoW M030 on MY01 Cab:
Front springs would be marked Green/Red
Rear springs would be marked Green/Red
Perfect! Thank you.
Loren,
My kit that I bought has the rear springs with pn 996 333 531 13 with a green dab on top and green/yellow on bottom. Also the rear stabilizer is pn 996 333 701 25. I'm stressin' out. Are these correct for a '01 C2 Cab 6/spd? Are the compensator rings supposed to come with the set?
Tom
sorry, I meant compensation PLATES. BTW all the other components seem correct;
Front springs - green/red
Front shocks - 996 343 041 16
Front stabilizer - 996 343 701 04
Rear shocks - 996 333 051 13
Rear stabilizer is pn 996 333 701 25 -- correct
rear springs with pn 996 333 531 13 -- maybe correct - these springs were based on VIN
Front shocks - 996 343 041 16 -- correct replaced by 996 343 041 17
Front stabilizer - 996 343 701 04 -- correct replaced by 996 343 701 21
Rear shocks - 996 333 051 13 -- correct replaced by 996 333 051 14
These are all older revs of parts - were they new?
Yes, just purchased from private party, still in plastic bags, never installed.
my vin is WPOCA29931S65XXX
I'm confused about tha compensation plates, which ones do I need? Also, I didn't get new bump stops, do I need new ones or can I reuse?
Thanks for all the help
Look at the other mark on the springs
Front:
1 green line = 6.5 mm thick compensation part.
1 white line = 3.0 mm thick compensation part.
Rear:
1 green line = 4.0 mm thick compensation part.
1 white line = 0.5 mm thick compensation part.
Springs are as follows;
Ft - green on top, green/red on bottow
Rr - green on top, green/yellow on bottom
How can I tell about the rear springs from the vin? is it in the PET or do I need to contact a dealer?
What about the bump stops?
The rear spring part number does not exist in PET anymore - so I can not verify it against the VIN range. Maybe a dealer has a way to look up old numbers but I don't. Sorry.
Only the rear bump stops change for M030.
US M030 bump stops are: 996.333.105.03
