Finally got my top operational. The problem was the relay which was new and worked but gave low voltage to the top motor. Replaced it with one without the green dot on the advise of the parts guy at Rector.
Now I have a new problem. The windshield part of the top latch has lost the left side bolt and the threaded part is gone. In other words the star headed bolt has no place to thread into. Whatever holds the threaded portion in place is broken. The consequences are that the windows go down partially when I hit a bump because the microswitch is slightlycrooked and concact is lost. Right now I have a small piece of foam holding the conatct but would prefer to bolt it down properly.
Is there a fix for this??
Painless
