Part numbers for the 'horseshoe' parts that surround the radio and air-conditioning controller.
(not the single 'horseshoe' that is fitted in the latter models but the left/right and top seperate parts.)
996.552.233.04.A03 Left trim -- MSRP $29.42 (as of Oct 2006)
996.552.234.04.A03 Right trim -- MSRP $29.42 (as of Oct 2006)
996.552.131.04.A03 Support frame -- MSRP $114.35 (as of Oct 2006)
Thanks for the number.
A follow-up question, can the individual pieces of the surround be replaced by the single horseshoe as fitted to the later models?
No, I don't think so. The center vent shape is different on the MY02 and newer cars.
But if you want to try I can get you the parts lists...
I may try this as we also have a Boxster (assuming the parts ar the same) that we can swap the parts from to at least see if this is feasible. I will let you know how we get on.
