I was wondering if there was a "simple" route to follow in order to drag a reversing camera cable from the rear bumper into the dash of the car to pop out where the stereo is located.
.. Porsche 996 C2
Some bright ideas would be most helpful.. thanks
YOu could try to bring it up through the engine compartment. In the non-e-gas cars the throttle cable runs through the firewall. You should find an open spot there :) YOu will have to take out the side panels on the driver side to get to that though..
