hi!
do i really need a ppi on a 15,000 mi dealer serviced 03 c2 cab???what should i be looking/listening for?
if so,does anyone know a good shop near stamford ct.?
should i call the dealership that serviced it?
o.k...guess that enough ?s for now!!
thanks in advance
look for oil leaks, such as RMS - do a search on it if you don't know what it is.
coolant expansion tank is common to leak, expensive labor
tranny is another.
ppi can be done at most dealers. you may buy the car thru the dealer if you want to fork $2-3k for a 2 year CPO warranty since you are already getting a PPI. By doing this, the seller sells the car to dealer which then marks it up as CPO by a couple grand and sell it to you.
