Hi I´m buying a replacement (used) engine. Have found two units. What is the difference between a m96 01 made 1999 and M96 04 made around 2000? The newer engine has more miles on it... and is more expensive.
Kare, Spain
Very little difference. Just realize that if it came out of a MY00 car then it likely has egas which your older car likely does not have. It is not too hard to change the intake from one old engine to the replacement. It would be harder to find a DME for for the egas engine (and other assorted parts).
