I am having an issue with my airbag light staying on and was told I need to reset the computer. I am in the Cincinnati, OH area and could use some help with this anyone. I will also let you know if anyone can help you as well. Thanks.
Brian
Brian
Brain,
I am a couple hours away for sure but if you find yourself up my way I'd be happy to reset it my my durametric software.
Most likly (this happened to me) you have the common concern with the seat belt lock having a problem with poor contacts. There was a TSB on this and lots of info on renntech.org if you do the search. I figured I was due for the fix or the cleaning at the least as the codes I pulled from the SRS light being on where related to this.
I reset the codes (SRS) and have not had it return in over a month now...and I didn't even do the contract cleaning.
I live in Mt. Gilead and work in Mansfield Ohio. Don't know if you travel up 71 at all from Columbus to Cleveland, as we are 45 to 60 minutes north of Columbus. We are in Columbus regularly too.
Shawn
Edited by rsfeller
