HI, my 2004 Boxster has a problem with the dash illumination & number plate lights, I have checked fuse A5 & replaced the number plate lights, but this problem still exists. I am out of warranty now, so can any one help !!!!!!
If you have a 2004, your warranty will expire in 2008 in the month it was purchased or 50K miles. I suspect you might have a faulty light switch
Hi, they warranty ran out April 2006 this year, have you heard of this problem.
According to my workshop manual, insturment cluster lights are B1 and B10 - both 15A. As mentioned above, you might have a faulty switch (part # 996.613.535.00 - approx $55 US). Good luck!
Thanks, Do you have a website which sells this item.
None specifically, but I'd check out some board sponsors or the usual like suncoast porsche, sunset porsche, auto atlanta, etc.
Hope this fixes your problem.
Hi all, I have replaced the Main Light Switch @ a cost of £77 which solved the problem. Not very good for a 2.5 year old car.
