I am thinking about changing the stock pads on my 03 C2 Cab. ( They are nearly useless in track use. Last time at jarama circuit in Madrid the brakes suffer a severe fading after 5 laps.... and its a 2 mile circuit with no more than 3/4 hard braking points ).
My question is : are the pagid blues the same as the Porsche Tequipment Competition pads shown on the Porsche web ? Which one do you recommend Loren for street/track use ( 80/20%) ?
Loren,
As a result of the 12 laps at the circuit that I mentioned, the dealer has changed the four set of pads, and THE FRONT ROTORS, that were absolutly ruined due to overheating !!! Is this a Porsche ?
I could not believe it.
Something does not sound right. I drive some a Laguna Seca which is very hard on brakes and likely put several hundred laps on the stock pads before changing them (and not the rotors).
If the brakes are overheating I would start by checking the age and conditon of the brake fluid, the front brake cooling ducts/spoilers and the you might also have someone out a PST2 on the car and see if there are any ABS errors recorded. It almost makes me thing the brakes are not releasing soon enough.
The brake ducts are flap 3 in Jeff's picture
