I'm looking to buy a 1985 Carrera 3.2 and need to know what to look for? its done 113000miles and has been owned by the last owner for the last 14 years. Any help would be apreciated, thanks.
I had an '81 SC for 15 years. Fairly similar in issues. The bigger $ area is the engine. They are somewhat prone to head studs corroding then snapping. Not as much after the factory upgraded to epoxy coatings. (not sure what year that was of hand) Also the valve guide seals tend to wear. So you may see smoke after the engine is started or higher oil consumption. With 113K either the previous owner took care of them or they will happen eventually.
Of course with a 20 YO car there can be a lot of things to look at. If the car was well treated it will minimize some things. Just get it to a reputable shop. For $2-300 they can do a good assessment.
Hope this helps.
  • 2 months later...
Hi buddy, this is my first post so here goes.
Body, check all the doors fit, and gaps around all panels good.
Engine, usually good if kept well serviced.
Gearbox
Type 915 on these cars, check it doesnt crunch, especially in 2nd 3rd
Clutch when was it changed
Exhaust, heat exchangers and pre-silencer,when changed, are they corroded.
BW
Paul
  • 5 years later...
