The 996 got fresh fluids this weekend.
ATE Blue brake fluid, Royal Purple 75W90 transaxle fluid, and 9 fresh quarts of Mobil 1 15W50.
The Royal Purple is AWESOME. I have used Redline and Mobil 1 in my track car in the past and had this Royal Purple laying around. I was going to use it next in my 951 but sold the car recently. The gearbox is smooth as ice. Redline was close and Mobil 1 was not that great, but the RP is amazing.
I had 2 5qt jugs of 15W50 left from my 951 track car left so I used it. I don't think it will be that big of a deal this time around. Normally, I would go with 0W30 or 0W40. Nothing like a little vasalene in the sump for the winter :-) !
I almost forgot.....
Here is what I did to my finger while breaking the fill bolt on the transaxle.
It might be broken, but I saved some $$$ by not having the dealer do all that.
Don't we all love wrenching on our cars!?
Edited by geoffbaltz
Hi! I have some RP 75W90 sitting in the garage from when I owned an M5, lots of guys there swear on it... I was wondering how much you needed for your 996? I also have a couple of bottles of RP Synthetic ATF sitting around, but I don't need this for the 996 do i? My car is a 98 996....
Thanks! I have never heard anything bad from people who put in RP on the M5 board... Just my 0.02
P.S. Ah the joys of battle scars from our cars are great!
It took 3 quarts. Everything I read is 3 to 4 quarts. I could probably use another 1/4 of a quart and will top it off when I get around to ordering some from summit racing or jegs.
You really just fill it to the bottom of the check/fill plug in the transaxle. The amount it takes to do this really depends on how well you drain the transaxle.
The ATF is for automatic transmissions.
Thanks! Yeah for dome reason the manual transmission on the M5 used ATF... Booop! Thanks for letting me know the amount of fluid, need a couple more bottles of Gear oil!
Phil...
