Hello,
Had coolant level problem, searched appropriate threads, took apart trunk liner and wood, sure enough... coolant leak due to cracked tank. Tool pants pictures helped a lot.
During my search, noticed a towing connection jury rigged to wiring, and the following piece that appears to be a towing hitch mount?:
Webasto 986-504-109-00
I removed licence plate and sure enough, there is a hole there with a female threaded insert for what I guess is a tow hitch.
Searched various sites, could not locate above part, can anyone confirm it is indeed a towing mount?
Was this a factory option or add on?
Where i can buy ball attachement?
Thanks a bunch,
Tony
Upon checking Webasto website, I believe that part is the spoiler mechanics.
However, I am still curious about the tow hitch assembly I seem to have,
seems factory, any clarification appreciated!
Duh, gosh I feel stupid. Female thread is for tow ring, as per manual...
Jury rigged electrical connection for lights on a trailer obviously done after market, no clue what was towed or how.
Please delete thread if appropriate.
Will add anything I learn to the coolant tank replacement thread when I tackle that.
Tony
