I'm getting a new gadge surround from Bumperplugs and need to remove the cluster to install it. I found boxster instructions here but I'm pretty sure the cluster is different on a 996.
After trying to debug my cruise control problem, I've become an expert at removing the console <_<
Actually it's amazingly similar, except you do not need to pull out the hazard switch. Pull off the hazard switch cover and the Torx screw is already visible w/o removing the switch. The other side is the 'fake' microphone and it is just as on the 986 boxster (pry it off and remove the Torx screw inside).
Tom
