Hi:
Sometimes I was wondering if my MY03 C2 has less gas milage than normal. My C2 is about 13 - 14 city and 20 - 21 highway. Odo reading is 17,000 miles. This gas milage sounds right or too low?
Thanks for your input....
Hi:
Is that your calculated MPG or what the computer says? Don't go by the computer. I would have to try hard to get as low as13 mpg. At worse, I have seen 15.5 or so, but average 20+ and as much as 27 - 28 cruising at 85 highway. Do you use alot of oil?
Edited by 1999Porsche911
According to the computer in my car, it's 20-22mpg on average.
I check manually everytime I fill up and my records show lesser figures of 18-19mpg.
On the highway on long trips I've done about 23-24mpg.
I have a tip, so it won't get as good mileage as a manual.
13 to 14 sounds like some hard track driving. Using odometer and gas tank fill numbers (not the dash readout), I get 17-19 city, 20-26 highway. Depends on fun or cruising style driving
At begining, I have tested a tank of gas to see if the computer is OK. Th result is very close, so I haven't bothered to calculate milage based on filling gas. I don't track and drive gentlely (compare to some p-car lover). :thumbup:
I doubt if I drive too less ;)
