I have an 02 996 cabriolet.
I noticed a spring had fallen off from under the seat the other day. It is the long spring that runs along the left side of the drivers seat. The spring is about 1 foot long, has hooks on both ends, and has a 3 inch rubber sleeve on one end over the spring.
I tried to figure out where this hooks to, but couldn't.
The passenger side is different so I can't use it to compare.
Does someone have diagrams as to how to replace this spring. Do I have to remove the seat or anything?
MM
No no lumbar support. It is a big spring you can see by just looking under the seat on the passenger side. I think it is to provide some resistance to the seat moving forward and back but I'm not sure.
MM
MM
Just your luck that I happen to have my standard seats out! lol
Here are two pics of the drivers seat that should help you re-attach it. If you need more detail let me know.
-Keith
In the picture directly below, the seat is leaning on its side and the front of the drivers seat (where your knees rest) is visible on the right.
In the image below, the seat is leaning on its right side with the front of the seat towards the left of the pic.
MM
I have a set of manual seats in my basement. but I'm away for the weeked. I'll take a look at them on sunday night if you don't get a answer by then. I believe the spring just anchors to a notch in the rear of the frame but I'm not positive.
Edited by Ed NY
