Should I be concerned about the audible hum coming from the idle stabilizer (996.606.160.01)? Car runs fine just the annoying hum when ignition on.
-1999 996 C2
That Idle Control Valve is just a solenoid. Mine does not hum - at least not that I can hear. Are you sure you are not hearing the secondary air pump at startup?
I can hear it from outside the car without the engine running. When I disconnected, silence. Car runs fine otherwise.
i have the same noise. can hear it without cranking the engine. is it normal?
Verify that it is indeed the ICV by unplugging it. If it is the ICV, it should make no noise and needs replacing if the noise bothers you. You may first try cleaning it by removing and spaying with carb cleaner.
