My drivers side headlight went out and i can not figure out how to remove the headlight lense! I have a tech manual but it isnt complete and i dont have this chapter. If anyone has any info that would help me i would really appreciate it!! Thanks!! <_<
You can download a copy of the owners manual on this site. It will have the info there around page 120 for my 03. Inside your tool kit, there is a hex socket with a sliding Tee handle, on the inside of the trunk, remove the carpet on the affected side, remove large round rubber plug, insert hex socket and rotate, I believe clockwise on the drivers side. you will here a snap and see the whole lens assy slide forward. When the lens has freed itself from the clip, you will see inside, slide completely out. The rear lid of the assy is held on by a snap hinge, release and open, all your light bulbe will be accessable. Take much care upon reinsertion to have all the guide tabs in thier appropriate slots. Pay attention to what goes where when removing. An easy job when you have done it a couple of times.
