I had 8.5 x 18's & 10 x 18's on my 996 before I changed to carrera alloys.
So fronts were bigger that yours & no problems.
My rears are a little smaller than the ones you want to fit - all I can say is that 10 x 18's fitted fine with no issues - so I would think 11 x 18's you would need clarity on.
Ro.
You must check the offset number, it's important, not only the width of the whells.
Remember that Porsche does many tests to calibrate the dinamic of the car with several whells. To use an non approved dimension could end in a non favorable car dinamic in hard turns.
