There is quite an annoying delay with servotronic (speed-sensitive power steering). Basically the power boost always come slightly later than I expected.
Is there any way to disable servotronic? I know on Audis you could just simply pull a fuse to disable servotronic modulation.
Thanks.
There is a fuse for it, but you will probably get a ! if you pull it.
Why do you want disable it?
It's speed-sensitive, and is a nice aid when parking, yet cuts off on the highway.
I don't like the over-boosted steering feeling, just thought I'd give it a try.
Do you know which fuse it is?
I think there is a servotronic relay somewhere under the dash but I couldn't find it.
Thanks.
Thanks.
Just found it. It is under the dash, near the steering column, the relay number is 462.
It firms up the low-speed steering quite a lot. I think the steering feel is much better now.
Have you talked to your dealer about the problems you are having?
I have zero-delay. It is a very boat like feeling at very low speeds, but not when you are 40+, at least on my car.
Not yet, but I dont think my servotronic has any problem. Just an experiment.
I quite like the heavier feel now, and there isn't any warning ! on my dashboard at all.
