Does anyone know if it is possible to get info from the CAN bus on a 996 Porsche? I am thinking about buying a Durametric OBD2 scanner and wondered if there was anything that can read more output than what is available from an OBD2 reader, short of a full-blown (expensive) shop diagnostic tool.
What information are you trying to see?
I don't know the answer to that question because I don't know what data is communicated on the CAN bus. I suppose that you could say that I would like to see any useful information that isn't currently available via the normal OBD2 feed.
...if there was anything that can read more output than what is available from an OBD2 reader
Yes, a lot more. An OBD II reader only reads/resets DME fault codes. The Durametric software can read and reset many other controllers in the car (i.e. ABS, airbag, heating/AC, alarm (read only, etc.).Durametric has a table of what it will do on a 993 here.
