hi!
I have a problme with Boxster s . that after long drive when i stop the car for a 10 min and then try start it again it have hard cranking problem. someone know how to reslove this?
(I check fuel filter , check fuel pressure ).... idea??? :beer:
"Hard time cranking problem" sounds like either a starter drawing too many amps or an old or weak battery. Check your battery terminals and starter main cable. Have your battery load tested for cranking amps also you might check your alternator output.
