Being used to a 6MT Subaru STI gearbox, the 2.5 986 gearbox/gear transfer is a real disappointment.
I need shorter throw, but the stock shifter is already quite heavy to operate. Does it get noticeably heavier to operate with a short throw kit?
Perhaps you should try the shifter in another Boxster. I would not describe the stock shifter feel as "heavy". Perhaps your car has a problem with the shifter or cables?
