I wonder what happened!
All of a sudden, around 2 in the afternoon today, I sat in the car, started it and I've got an Airbag error and a light on the dash.
Now it's been doing that since, everytime I start the car. :angry:
It's a 2002 C2 Coupe.
Once the airbag light comes on it can only be turned off with a PST2, PIWIS or the Durametric Software. Besfore it is reset thye should read the fault code so you can see what turned it on - and correct the problem. My guess is it is likely a seat belt buckle (unless you took the steering wheel off recently). ;)
