Well i had to go and get tabs for the car and have my emissions done. came up with two codes p1531 (cam sensor i believe) and the other is P0441: Evaporative Emission Sysyytem Incorrect Purge Flow
anyone know what this is?? :oops:
my car is a 1999 C2 6 speed with Fabpssed mufflers, headers, cat-bypass, fab-speed intake with BMC filter and Uni-chip piggy back computer. :drive:
P0441 Fuel Tank Ventilation System - Above Limit
- EVAP canister purge valve open
- Pressure sensor faulty
P1531 Camshaft Adjustment, Bank 1
- Open circuit in triggering wire.
- Open circuit in B+ supply.
- Actuator faulty
BTW... all the fault codes are listed here.
- Actuator faulty
Thanks Loren,
Do you know of an easy fix for P0441? and where the EVAP is located?
Has anyone had any issue with this part before, or just come down to a replacement? Mine is installed the same as the picture, but is it just a faulty unit?? Thanks
- Actuator faulty
Loren, I did order the purge vavle, SUnset said they sell quite a few of them..
I am going to replace the actuator becuase the car is starting to act like the Variocam is not really kicking in... is that an easy process?? :drive:
