ROW 030 2004 C2 6spd
Just wanted to check and see if I received the correct parts and what compensation plates to use on the install. All parts have a green dot marking.
Front Sway Bar 996 333 701 26
Rear Sway Bar 996 343 701 21
Strut 996 343 041 21
Shock 996 333 051 34
Springs have markings of Green/White then Front has a orange dot and rear has a blue dot. Thanks for the help can't wait to get this installed and test it on the track this weekend.
