Hi friends, I have many problems with top of my bosxter of 1998, Top light is turn on on dash.
My problem is that when I press open button windows go down but top doesnt make anything, I already test my relay on other porsche and its work ok, fuses are ok, I make Micro switch trouble shooting sequence and I only have problem with 8 step, When I insert direct power to motor it's work ok( 12+ black, 12- green), then I measure green and black wires of power motor conector and result was = batery power but when I plug connector to motor measure is 0, Can any one help me? I think is problem of motor thanks and regards from Spain.
  • 5 months later...
Where did you find the black and green wires clk2004? Did the top work if you keep the battery connected to those wires? Does the top work the other way if you reverse the polarity? Thanks.
