I just had my 60k maint done and also had fabspeed headers and cat deletes put on. The fabspeed site says you might get a cel but car will be fine. The car runs 100% normal and the flashing goes away after only a few seconds. Is this a normal cel or does the flashing mean really bad things?
I took the car to autozone and had the codes read:
P0300
Random/Multiple Cylinder Misfire Detected
P0306
Cylinder 6
Misfire Detected
P0304
Cylinder 4
Misfire Detected
P0305
Cylinder 5
Misfire Detected \\PO175
System Too Rich
(Bank2)
I had them cleared and seems fine. Will drive a littel tonight to see if it comes back. It had been a few weeks since driving it and i bogged bad once so that could have been it.
All of your problems are on bank 2 (cylinder 4-5-6).
Did they change your spark plugs on your 60k service? If so, they should look for cracked coils on that side.
If the coils are ok then I would look at the Variocam adjuster on that side of the engine.
yeah they changed the plugs. I drove the car for about 70 miles and the light came back on at about 70 miles. The car still drives fine and feels solid. I will call the shop that did the work and see if he can look at it.
