I have a Motiv Brake bleeder that I have used on VWs and Japanese imports. But none of these cars had the sophisticated brake systems like the current Porsches and Audis.
My question is: can I flush the brake fluid from my '05 Cayenne S with the Motiv Brake bleeder (going from each corner of the car, farthest to closest to the brake master cylinder), or is their a special procedure to deal with the ABS system? I searched the forum but did not find anything specifically on this topic.
Any input would be appreciated.
Andre
If you have the tool (right now only a PST2 or PIWIS) -- you can activate the ABS and flush it too. But most folks don't have the tool and unless you are changing grades (DOT3 to DOT 4) you likely will not have any problems.
Thanks Loren. I did read your write up for the 996 brake fluid flush.
Any recommendations on what brand of brake fluid? Our Cayenne S is a daily driver; no track events.
