Hi Chaps,
I've recently changed rear pads following trackday and wear indicator light coming on.
I changed the rear pads, checked the sensors and they look intact, however the wear light is still on. I'm puzzled?
Any suggestions much appreciated.
thanks
Neil
The wear indicator is just a wire. When continuity is broken then it turns the light on. One (or more) of your sensors has a broken connection. If you have an ohm meter you can unplug each one and test them.
