Are you talking about using the RoW 993 RS motor mounts on a GT3 (mk2)?
If so, you will need longer bolts and the parts below:
993rs_motor_mounts.pdf
There was a performance package offered, X73 and X74 which consisted of a stiffer motor mount along with performance and suspension upgrades. These mounts, stiffness wise, fall in between the ROW 993RS mounts and the standard 996 mounts. The problem being my '04 gt3 has 993.375.049.06 series mounts which I believe are the standard 996 mounts and according to the PET I should have 996.375.049.90. I'm not sure why there there is a discrepancy.
What I'm looking for, are the mounts that would be used with the X package upgrades. It may very well be that 996 number but I have no way of knowing. Porsche has so many mounts and different types it's hard to know what is really required. Some use the same P/N but have a painted color code to identify them. The more I learn the more confusing this whole thing becomes.
TIA
Ray
The parts list only shows the X74 kit package- not what is in it.
Try Jeff@sunsetimports.com - he can likely find out what is in the package.
Tell him you wan the parts list for the RoW X74 package for a C2.
