Here's what I want to do myself in my garage on my '05 997:
Change Oil & filter (do I need to elevate car?)
Change engine air filter
Change interior charcol air filter
Purge brake fluid & repalce
Need DIY how-to information, tools required, parts #s, and source for parts.
Paulg1
Other than the engine air filter those tasks are the same as on the 996. Have a look in the 996 DIY section under maintenance.
The 997S air filter change is here in the 997 section. I'll have a look and see how different the 997 (non S) is.
Thank you very much.
Will follow your advice.
I did look at changing air filer on S model. Am guessing for non-S, maybe it is self-evident just looking at it. A couple fasteners?
You folks who have done this - where'd you get your wheel ramps? Any other advice?
Replacing the air filter takes some time. There are a lot of srews to undo before you can split the air cleaner
box.
Paul Larson
