In an attempt to help my brake problems, I'm replacing my 10-year-old OEM brake lines with stainless brake lines from Pelican.
I plan to wedge the brake pedal down to close the system, and I will be using flare wrenches to loosen the lines. Any other helpful hints? Anyone else done this?
Am I stupid to be changing these?
Install these because you want or like them, any benefit seen will most likely result in air being bleed out of the system. I have sold, constructed, installed braided ss brake lines for 30 years and found little improvement solely due to the change. Stock rubber lines are designed to last many years and very little energy is lost due to expansion. This could be the case on a car from the '70s or older but unlikely on yours.
