electrical question
I have a 99 C4 tiptronic and I was having a problem starting the car. Turn the key and nothing happens. I replaced the ignition switch and got the same. So I ran a meter to the ignition switch, a heavy gauge wire (yellow I believe) gives off power when the key is turned. I ran this wire to the starter and the car starts fine. Does anyone know what is inbetween the iginiton switch and the starter? The wire coming off the ignition switch was probably around 12 gauge so I didnt think it would need a relay to give the starter good voltage. I can start the car fine now but I dont like an "aftermarket" wire running to the starter. Thanks for any tips.
