:( I own a 2002 986 that suddenly developed a problem with the directional signals. When I go to use the directionals, the four-way flashers come on instead. It does not matter if it is right or left, same results.
Help!
Is this a simple fix like a flasher module? :unsure:
If you had asked me a few years ago I might have known the answer. I had funny things going on with the hazzard lights and turn signals. They are tied together. Now I don't remember. I spoke to Peter and ended up replacing some bulbs and the hazzard switch.
I would find another car and swap the flasher relay and see if that is the problem. It is the one with the yellow arrow.
Help!
Thanks, I'll give it a shot.
Help!
As it turned out the problem was with the Hazard Flasher switch. Jiggleing it solved the problem
Help!
Sounds like classic relay failure I've had happen on many Saabs and BMW. I would hope its a rather standard unit that could be had at most local auto stores, maybe not. Regardless they can be cracked open and the contacts cleaned for another year of service.
