Well anything is possible... for the right amount of money.
Here are your really big issues:
TT is different base engine (same as GT2 and GT3).
All current TT's are 4WD.
Both rear fenders would need to be reworked to adding cooling vents and fit the turbos.
Likely easier and cheaper to buy a TT Cab ;)
so I take it parts are really expensive!!  by the way, thanks for the side skirt instructions
Engine alone lists for $42,000 (and that is exchange).
I didn't even mention suspension or brake changes to match the turbo either...
You can try the www.evoms.com supercharger modification which requires npo body work and gives for 420bhp and 360 torque for 10k.
The TT engine requires a different transmission as well. Even if you can find a used engine/tranny combo and are able to sell the 996 engine and tranny, this swap will cost you $40-50K not including all the other changes Loren mentioned. I agree that either supercharging or just buying a TT Cab is a much more cost effective solution.
Karl
  • 9 months later...
sorry to dig up an old thread, but I'm new here and this seemed to be the exact topic I was hoping to explore...
I come from a DIY background and have built many one-off turbo cars (i.e. starting from scratch with a welder and pile of mandrel bends, building the headers and intake tubing, completely revamping the fuel system, wiring in a standalone engine management system, etc.)... personally, the building and transformation of a car is what's most enjoyable to me... (not to mention that $40k+ for a "real" turbo motor seems completely insane being as i've built motors that made 1400hp for $10k)
so let's say a person doesn't care about building a part-for-part identical vehicle to a factory TT, but rather just wants to turbocharge their N/A 996... let's talk about strength of the components: common sense would say that if the engine, tranny, clutch, axles, etc. can handle the extra hp from a supercharger then why not the same increase from a turbo? are there known limitations of the N/A motors? what sorts of things are fundamentally different from the TT motor? is it actually a different block? different cylinder head castings? how about the tranny and the rest of the drivetrain? at what power level does the N/A 6-speed tranny become "iffy"? i'm not looking to get too radical with the project, but at the same time, i've never owned a "sports car" that made less than 450hp and I'm not about to start with my first Porsche! any pointers to good tech info along these lines would be greatly appreciated!
thanks,
Jeff
