ebay guy has them cheap. easy swap from the top strut or are messing with struts a real job for a real specialist?
could the fact these things are wasted be why i hear a front end rattle on really bumpy roads that is subdued as quickly as front gets back on the road?
Do these bump stops belong inside the gator?
Are you sure your rattle is not a loose front swaybar? (fairly common)
will check out, are the bushings usually shot? I've seen sway bars hanging on other cars I'e owned (neglected).
Is this why I see swap bar kits on ebay or are those upgrades for track needs?
More importantly are we the only two guys sitting at home on a Friday night?
