what is the trick as i'm beating this poor grey connector up bad. Great info on the horn bushing problem but nobody mentions taking the airbag off in detail! obviously they are not having the issue I am.
The yellow connection on the back of the air looks like it shouldn't be removed and the grey one going into the column will not come out with pliers when the clip is pushed up.
Is this supposed to come out, as i'm afraid I am going to break it!
Don't remove the gray one. The yellow clip connected to the steering wheel airbag is the one that comes off. Put a flathead screwdriver behind it and pry up a little to pop it off. Make sure the screwdriver is close to the center of the cap so you don't damage the plastic cap. :cheers:
got it! For some reason that one looked fragile...but he poped right off!
