Hello all,
I am experiencing a problem with a mobile phone SIM card on a 03 CYN S PCM.
You install the card, an it displays the message "Synchronizing address book".
This can take ages, and in the end nothing happens. It doesn't read the names and numbers as it used to. The SIM card works perfectly on my mobile. What is wrong with it ?
TIA
Actually I have just experienced the same problem with a 05 Cayenne S ....
I have also had the PCM switching on and off without any reason while driving ... so 30 minutes ....
  • 6 months later...
  • 4 weeks later...
Have your dealer (or OPC) check to see that you have the latest firmware in your PCM.
Actuallt firmware was up to date, but the software was like making a "loop", so the overall PCM was overheating and then after 45 minutes would shut itself down.
My dealer changed the entire PCM unit.
