I have an '04 Cayenne Turbo which I bought new in August 2005. I was told at the time that because it was a 2004 model that it needed to be recertified by the shop, which it was.
Now, the dealer has called me (a year later) and asked me to bring it in because Porsche has asked all dealers who recertified 04 Cayennes to recertify them again. When I asked why, he did not know and said that all he knew was that he been given 7 files to contact and set up appointments for recertification. Can anyone tell me why this would be and what they are looking for?
Thanks.
John.
Maybe these have something to do with it:
Make : PORSCHE Model : CAYENNE TURBO Year : 2004
Manufacturer : PORSCHE CARS NORTH AMERICA, INC.
NHTSA CAMPAIGN ID Number : 04V072000 Recall Date : FEB 16, 2004
Component: SEATS
Potential Number Of Units Affected : 4144
Summary:
ON CERTAIN SPORT UTILITY VEHICLES, THE DRIVERS SIDE SEAT FRAMES WERE NOT ADEQUATELY WELDED.
Consequence:
IN THE EVENT OF A CRASH, THE SEAT FRAME COULD BREAK, INCREASING THE RISK OF A CRASH.
Remedy:
DEALERS WILL REPLACE THE DRIVERS SIDE SEAT FRAME. OWNER NOTIFICATION BEGAN ON MARCH 29, 2004. OWNERS SHOULD CONTACT PORSCHE AT 1-800-545-8039.
Notes:
PORSCHE RECALL NO. A306.CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATIONS AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
NHTSA CAMPAIGN ID Number : 04V231000 Recall Date : MAY 17, 2004
Component: SEAT BELTS:REAR
Potential Number Of Units Affected : 19175
Summary:
ON CERTAIN PASSENGER VEHICLES, THE REAR SEAT BELT LATCH ATTACHMENT BOLT IS INSUFFICIENT RIVETED.
Consequence:
IN THE EVENT OF A CRASH, THE SEAT OCCUPANT MAY NOT BE PROPERLY RESTRAINED INCREASING THE RISK OF PERSONAL INJURY.
Remedy:
DEALERS WILL INSPECT THE BELT BUCKLE LATCH AND, IF NECESSARY, REPLACE THE LATCH. OWNER NOTIFICATION BEGAN ON JUNE 1, 2004. OWNERS SHOULD CONTACT PORSCHE AT 1-800-545-8039.
Notes:
NHTSA CAMPAIGN ID Number : 04V593000 Recall Date : DEC 09, 2004
Potential Number Of Units Affected : 31000
Summary:
CERTAIN PASSENGER CARS FAIL TO COMPLY WITH THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 208, "OCCUPANT CRASH PROTECTION." ALL THREE REAR SEAT POSITIONS AND THE FRONT PASSENGER POSITION ARE EQUIPPED WITH SEAT BELT RETRACTORS THAT HAVE A LOCKING FEATURE WHICH CONVERTS THE RETRACTOR FROM AN EMERGENCY LOCKING RETRACTOR (ELR) MODE TO AN AUTOMATIC LOCKING RETRACTOR (ALR) MODE FOR THE PURPOSES OF CHILD RESTRAINT INSTALLATION. THE BELT MAY DEACTIVATE THE ALR MODE WITH CERTAIN CHILD RESTRAINTS.
Consequence:
WHEN INVOLVED IN A CRASH, THE CHILD RESTRAINTS MAY NOT BE PROPERLY SECURED INCREASING THE RISK OF INJURY OR DEATH TO THE SEAT OCCUPANT.
Remedy:
DEALERS WILL PERMANENTLY INSTALL A CLIP IN EITHER OF THE AFFECTED REAR OUTBOARD SEAT BELTS AND PROVIDE AN OWNER'S MANUAL INSERT. THE CLIPS WILL PREVENT UNWARRANTED CONVERSION FROM ALR TO ELR MODE WITH CHILD SEAT INSTALLATION. THE RECALL BEGAN MAY 17, 2005. OWNERS SHOULD CONTACT PORSCHE AT 1-800-545-8039.
Notes:
PORSCHE RECALL NO. A506. CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATIONS AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
NHTSA CAMPAIGN ID Number : 03V351000 Recall Date : SEP 24, 2003
Component: EQUIPMENT:OTHER:LABELS
Potential Number Of Units Affected : 326
Summary:
ON CERTAIN SPORT UTILITY VEHICLES, THE AFFECTED VEHICLES MAY BE MISSING THE GROSS VEHICLE WEIGHT RATING (GVWR) AND GROSS AXLE WEIGHT RATINGS (GAWR) ON THE CERTIFICATION LABEL AS REQUIRED BY PART 567.4(G)(3) AND (G)(4).
Consequence:
THE VEHICLE OPERATOR WILL NOT BE INFORMED OF THE VEHICLES GVWR AND GAWR.
Remedy:
DEALERS WILL APPLY THE CORRECTED LABEL. OWNER NOTIFICATION BEGAN ON DECEMBER 22, 2003. OWNERS SHOULD CONTACT PORSCHE AT 1-800-545-8039.
Notes:
PORSCHE RECALL NO. A401. CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATIONS AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
NHTSA CAMPAIGN ID Number : 04V069000 Recall Date : FEB 16, 2004
Component: ELECTRICAL SYSTEM:WIRING:FRONT UNDERHOOD
Potential Number Of Units Affected : 10637
Summary:
ON CERTAIN SPORT UTILITY VEHICLES, THE MAIN WIRING HARNESS WAS INCORRECTLY ROUTED. DAMAGE TO THE MAIN WIRING HARNESS CAN LEAD TO THE FAILURE OF VARIOUS ELECTRICAL SYSTEMS.
Consequence:
IN EXTREME CASES, TO A CABLE FIRE BENEATH THE INSTRUMENT PANEL IN THE PASSENGER COMPARTMENT.
Remedy:
DEALERS WILL RE-ROUTE THE WIRING HARNESS. OWNER NOTIFICATION SCHEDULE BEGAN ON MARCH 29, 2004. OWNERS SHOULD CONTACT PORSCHE AT 1-800-545-8039.
Notes:
NHTSA CAMPAIGN ID Number : 04V071000 Recall Date : FEB 16, 2004
Component: POWER TRAIN:AUTOMATIC TRANSMISSION
Potential Number Of Units Affected : 4099
Summary:
CERTAIN SPORT UTILITY VEHICLES MAY HAVE HAD A TRANSFER CASE INSTALLED THAT COULD, DUE TO CHANGES IN THE HOUSING CASTING, RESULT IN THE OIL PUMP ROTATION. SHOULD THIS OCCUR, OIL STARVATION OF THE INTERNAL GEARS MIGHT RESULT.
Consequence:
CONTINUED OPERATION OF THE VEHICLE COULD RESULT IN A FRACTURE OF THE TRANSFER CASE HOUSING. INCORRECT TORQUE WOULD THEN BE APPLIED TO THE DRIVEN WHEELS OR OIL COULD LEAK AND CONTACT THE TIRES.
Remedy:
DEALERS WILL INSPECT THE TRANSFER CASE HOUSING AND, IF NECESSARY, REPLACE THE TRANSFER CASE. OWNER NOTIFICATION BEGAN ON MAY 3, 2004. OWNERS SHOULD CONTACT PORSCHE AT 1-800-545-8039.
Notes:
It could also be a survey of product liability issues related to the 04's which by anyones standards were sub par
Component: SEATS
Summary:
ON CERTAIN SPORT UTILITY VEHICLES, THE DRIVER’S SIDE SEAT FRAMES WERE NOT ADEQUATELY WELDED.
Consequence:
Remedy:
DEALERS WILL REPLACE THE DRIVER’S SIDE SEAT FRAME. OWNER NOTIFICATION BEGAN ON MARCH 29, 2004. OWNERS SHOULD CONTACT PORSCHE AT 1-800-545-8039.
Notes:
PORSCHE RECALL NO. A306.CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION’S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Summary:
Consequence:
Remedy:
Notes:
Summary:
Consequence:
Remedy:
Notes:
PORSCHE RECALL NO. A506. CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION’S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Summary:
Consequence:
THE VEHICLE OPERATOR WILL NOT BE INFORMED OF THE VEHICLE’S GVWR AND GAWR.
Remedy:
Notes:
PORSCHE RECALL NO. A401. CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION’S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Summary:
Consequence:
Remedy:
Notes:
Summary:
Consequence:
Remedy:
Notes:
